Can VATS be added to a 7747?
I have a C1500 truck LO5 i'm putting into a 91 camaro I bought with a blown LO3. I understand that the truck prom cant be installed into the 8746 ecm, so I'm going to use the 7747 that came with the donor motor. I would like the VATS to work. How would I go about this? Can a new prom be burned with vats turned on?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Can VATS be added to a 7747?
Vats can’t be added use the 8746 ecm, you can use anlu or atjp prom and enable vats on it.
Engine: Lb9
Transmission: M20
I have a atjp prom from a caprice and can burn a copy with vats if you don’t have the capability send me a personal message.
88 Z-ROC
Jan 21, 2014 06:28 PM
