Need help in sending data log file to email address
Old Jul 27, 2018 | 06:24 AM
83 Gman's Avatar
Hi
I need instruction how to send an EBL data log to someone.
Never got into sending info like that.
Is it the same format as sending a screenshot?
Old Jul 27, 2018 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help in sending data log file to email address
You can zip or compress it first to make it smaller. Other then that just attach it to the email. Usually a paperclip icon is available to do this.
Note that you want to send the .dat file, that is the raw data log.
RBob.
Old Jul 27, 2018 | 07:44 AM
83 Gman's Avatar
RBob.
Don't know how to zip or compress, not that savvy with things like this.
I'm guessing to attach it to an email I would have to save it to a file location first then attach it.
Would sending a Bin file be the same way?
Old Jul 27, 2018 | 03:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When you create the data log it will be saved into a folder. Can send it directly from there. To start a data log, in the WUD: ALT+F, D. Then navigate to the folder you want to save it in. All incoming data from the ECM will go into that data log.
Attaching a BIN is the same as attaching an image or the data log.
RBob.
Old Jul 30, 2018 | 07:58 AM
83 Gman's Avatar
RBob
You say the data log will be saved into a folder. Where would I look for that folder? Or are you saying create a new folder for it, then put it in it?
When you say to start one press ALT+F,D by pressing three keys at once?
Told you I'm not savvy at this. Never got into other functions my PC can do.
Old Jul 30, 2018 | 08:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The data log will be saved in the folder of your choice. You can create a new folder just for the data logs.
ALT+F, D: hold down the ALT key and hit the F key. The file menu will drop down. Hit the D key to open the save data log dialog. Navigate to the new folder (or make one) and type in a name for the data log file.
RBob.
Old Aug 1, 2018 | 12:11 PM
83 Gman's Avatar
Thank you for the explanation.
Rumblin70SS
Aug 20, 2012 01:26 AM
91ZLS1
Jan 20, 2003 11:18 PM
86TpiTransAm
Nov 18, 2001 08:16 PM
