Dash Light Question
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Dash Light Question
Have a 90 Camaro. Had a dash light come up that is: int’l fail. What does that mean?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dash Light Question
Sure it wasnt inflatable restraint warning light? AKA the Airbag light? On start it should flash a few times to show it's working, then go out when it completes it's diagnostic check. If it comes on at any other time, I'd honestly just find the fuse and pull it. After a day or two, unplug the big YELLOW plug under the column with the airbag warnings all over it, and to make the light go out, pull the cluster and remove the bulb.
Because here's the thing... Early airbags are dangerous. I'd rather take my chances with the crash than have the crash plus an early attempt at an airbag exploding in my face. That and who's going to pay to fix the early airbag system?
streak_06
Exterior Parts Wanted
Apr 5, 2014 12:34 PM
BmoreKnight
Apr 19, 2012 09:51 AM
wasp
Mar 3, 2002 01:35 PM
PurplePa$$ionz28
Dec 18, 2001 05:41 PM
