Stock PROM's - What's compatible?
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Can anyone tell me a list of cars/trucks that would have the PROM for my 92 RS L03 w/ 700R4 and your opinions on which would be best? Also, Can PROM's go bad and just fail?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stock PROM's - What's compatible?
It’s very rare for a prom to go bad. The 1228746 ecm was used on 89-92 f body’s and I’m not sure what year but it was used on the b body with a 350 automatic.
I think the latest tune was the axkt for your application.
Engine: Lb9
Transmission: M20
Engine: 305 / 350
Thanks a million, any insight on what makes/models I can snag one from? Such as C/K 1500 trucks, s-10's, caprice's, etc...
Engine: Lb9
Transmission: M20
The programming language is different. You could use a truck 1227747 from a 305 tbi automatic truck. But the prom on the link is cheap . The symptoms of a bad prom is rapidly blinking check engine light. I’m not sure on your ecm If code 41 or 51 would show.
Engine: 305 / 350
Went out to a local JY, they ran the 1992 Camaro RS 5.0L V8 through interchange applications for ECM's and came back w/ same year range Chevy Caprice. They had a 1989 & 1990 on the yard. Checked them out and the 1990 (VIN # 1G1BU54E6LA117153) was complete with a nice shiny 1228746 so I picked it up.
Anyone know the difference in the "tune" of the ATYR & the AXKT PROM's?
Engine: Lb9
Transmission: M20
Atyr will work it’s for a 305 tbi automatic. I don’t have that file to do a file compare.
Engine: 305 / 350
I've run the ATYR PROM and yes the car's derivable but that's it. I ended up ordering the AXKT PROM as you suggested, made the seller an offer of $19.99 and the seller accepted. So once it arrives I'll install it so I can at least know what the true factory tune performs like.
In the mean time, I did put the HyperTech HYP-122362 PROM back in (the newest 1228746) along with a 160 degree thermostat... runs noticeably different until code 44 pops, then performance takes a nose dive but that's another topic.
Engine: Lb9
Transmission: M20
Have you started a thread on your lean code 44 ?
Car: check
Engine: check
Transmission: check
ATYR is for a Caprice, which is why it is lame in your 3rd gen.
Code 44 (O2 lean) can be the sensor or a failing fuel pump. It could be something else, such as the hypertech chip, Does the code ever pop up with the Caprice PROM?
RBob.
RBob.
Engine: 305 / 350
Yes that code popped no matter what ECM/PROM combo was in use...
Engine: 305 / 350
*SOLVED*
Picked up a AXKT 1113 at a local yard today. It was pulled from a 90 RS w/ VIN # 1G1FP23E1LL130325. Total cost $0.00, cost was "included" with the Instrument/Gauge Cluster I snagged for $35.
So now that I have the Stock PROM, and another AXKT 1113 on the way that i'll keep as a spare I do consider this thread/matter resolved.
Thanks everyone!
Thanks everyone!
steven72192
Sep 2, 2013 11:33 AM
My1986IROC-Z
Nov 18, 2005 09:11 PM
