Best base file to start with on a boosted TPI w/411 swap?
Old Aug 2, 2018 | 11:24 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I finally got all my stuff to do my 411ecm swap. I am curious what other 411 guys started with as far as a base tune file to get the car running. I will be running a speed density/2bar operating system. Thanks.
Old Aug 2, 2018 | 11:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Best base file to start with on a boosted TPI w/411 swap?
I used a boosted 6.0 ls file as a base my buddy did at the time. He did part of the tuning then i took over. Worked well
Old Aug 2, 2018 | 01:26 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Did you keep the 700r4 or did you upgrade to the 4l60e for better control by ecm? If you kept 700, how are you handling the lockup ,411 do it?
Old Aug 4, 2018 | 11:14 AM
TurboedTPI's Avatar
Car: 92 Formula 350
For now, the 700r4 is still in it. For some reason the lock up never worked. I'm not sure the issue there. But i'm not too concerned about it right now. Down the road I'll probably end up doing a 4L60e. I have a hook up on a very reputable local trans builder who specializes in 4l60e's. There are many cars around here in the 9's with his trans. finishlinetrans.com
87_TA
Feb 19, 2014 09:32 PM
85SS/85GN
Dec 5, 2009 06:15 AM
87transam5.7tpi
Jan 26, 2002 02:34 PM
doc
Jan 26, 2002 08:51 AM
