Ebl flash shift light for 2-step rev limiter?
Old Aug 25, 2018 | 07:47 PM
89377STROKER's Avatar
I was wondering if some how i could use the ebl flash shift light output to possibly control a home made 2-step circuit? I was thinking it may be possible if the output was wired to a relay, or set of relays could possibly be wired to a monetary switch that when pressed, would allow the shift light output signal to be sent to a relay and cut the ignition coil signal to create a low-cost/diy 2 step system? If im way off on my thinking? let me know....just been toying around with the idea lately. Thanks guys!
Old Aug 26, 2018 | 05:18 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Ebl flash shift light for 2-step rev limiter?
There is a way to make a two step rev limiter with EBL system. Do a search here, Bob laid it all out. From what I remember it works with the KR system and uses a push button switch wired into the KR sensor with a resistor. I have a wiring schematic somewhere but couldn't find it just now. If you can't find the thread let me know.
antman89iroc
Oct 5, 2018 10:34 AM
IroczInOz
Jun 28, 2006 10:46 PM
arlockstedt
May 19, 2005 09:00 AM
fisherbody86
Aftermarket Product Review
Jan 27, 2004 07:57 PM
