Is there a way to use/configure EBL flash to provide a 2 step function for racing? Or maybe just have the rev limiter at a lower setting (say 3500 or so) that is initiated by a switch, that goes away when the switch is deactivated and no upper rev limit?
I'm running a stick shift and want a way to control the rpm at the line. I can rely on the MSD box for the upper rev limit but thought maybe there's a way to use EBL to set a lower rev limit.
On the other hand I thought possibly of using the "high idle" function on a push button or wired in with the clutch pedal switch to hold rpm at the line. Any thoughts appreciated.
I was reading up on the EBL information about the high idle function. It says the upper idle speed is limited by the max IAC and an "upper calibration limit of 3187". Maybe this can be manipulated to have the upper calibration limit user defined?
Not sure what you mean by having a user defined upper High Idle limit. The 3187 RPM upper limit is as high as the user can set the high idle RPM. The actual value for the high idle is set by the user.
If you are willing to give up the knock retard system it can be used for a 2-step. Set the knock parameters up so that the knock enable RPM is the limit. Can then ground the knock input to set up continuous knock retard.
Note that the EBL Flash ECM, although not the P4 or SFI-6 ECM, will need a 1K pull-up on the knock input.
RBob.
You're the guru for sure.
I probably need to look into the high idle further but I hadn't seen the user defined table.
That is a very interesting use of the knock retard. To make sure I understand your suggestion, I ground the knock input to "enable the limit" base on a switch (button or whatever) and then open that circuit to disable the limit. Please further explain how I would connect the 1k pull-up resistor. I basically need a 1k resistor going around the "arm" switch to ground so the knock lead is either connected directly to ground or through a 1k to ground. Is that correct?
On a different subject, shift light. Can the LED's be the newer bright LED as long as the current doesn't exceed the max value? I am considering using a LED flash light modified to work off 12vdc with resistors. I bench tested it last night to get the resistor value but still need to double check the current. As long as I am under the limit (240mA I believe) it is ok for the ECM to drive it directly.
Reason: Correct mA value
It is just a single value:
IAC - B9in Idle Speed
The 1K 1/2W resistor goes between the knock input to the ECM (pin B7) and IGN+.
When that input is grounded the ECM goes into knock mode. This causes the ECM to retard the timing.
Set the knock MPH threshold to 0, and the RPM threshold to the RPM for the spark retard.
There are attack and decay tables for how quickly each is done. Plus maximum spark retard tables for PE mode and non-PE mode.
On a different subject, shift light. Can the LED's be the newer bright LED as long as ... As long as I am under the limit (240mA I believe) it is ok for the ECM to drive it directly.
I did not. The main reason is I have KR disabled via the parameters but do still monitor knock counts. I didn't want to either enable KR or lose counts.
However, I have taken a different approach. Since my car is a stick shift I simply take the SA to 0 in the RPM/MAP range at the starting line. For instance, it is set to 0 above 3200RPM below 50MAP. It isn't a "rev limiter" per se but does help keep revs very close to the RPM I want on the line. As soon as the clutch starts to come out and load the engine the MAP changes to a portion of the table where SA is normal. And that's how I chose to do it.
