92 z data logging issue
Car: 92 z28 (sons car) 2008 duramax
I am trying to data log my sons car after an intake and head swap because of a hesitation-stumble just off idle but am running into some issues. With everything hooked up and recording, the dash feature on tuner pro rt always shows 4500 rpm, 55mph, 98 degrees and spark advance at-68, regardless of if I’m driving or idling. The fuel tables will only populate 4-5 blocks. I’ve searched on the forum and came up empty handed. If anyone has a link of can point me in the right direction, it would be much appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 z data logging issue
Are you sure your using the right adx ?
$8d for tpi speed density
or $88 for 3.1l
or $88 for 3.1l
Yes it’s $8D. There wasn’t one for a 92 but from what I’ve gathered, this is the one I need.
Engine: Lb9
Transmission: M20
Rumblin70SS
Aug 20, 2012 01:26 AM
