Aftermarket ECU options
Old May 27, 2019 | 04:48 AM
Dazza Wilton's Avatar
I have a 90-92 7730 speed ensity system and would like to run an aftermarket ecu for better data logging and tune on the fly. Any sugestions on a good system would be most helpful
Old May 27, 2019 | 12:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Aftermarket ECU options
Dynamic efi ebl p4
Old May 28, 2019 | 02:13 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I use Megasquirt. You can download a demo version of Tunerstudio and play with it to get an idea of the interface.
http://www.tunerstudio.com/index.php/tuner-studio
I used the Microsquirt module which I installed in a factory ECM case:
http://members.cisdi.com/~anesthes/projects/megasquirt/
Originally I ran it with a distributor, but I've since upgraded to distributorless ignition using EDIS coils and a 36 tooth trigger wheel.
-- Joe
Old May 28, 2019 | 04:25 PM
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
I'm using a Holley HP ecu with the terminator throttle body. I'm not sure if its a cost effective approach but I like the capabilities it has. I would also look into the megasquirt ECU as the other poster stated.
seiplentz
Aug 19, 2019 06:02 PM
Veaceonee
Jan 19, 2013 10:19 PM
71ChevelleSS
Aug 21, 2010 04:24 PM
BMmonteSS
Feb 22, 2003 04:38 AM
