3rdgen 305 engine engine running to fast on idle
Old Aug 9, 2019 | 12:40 AM
palysell's Avatar
Car: 1984 camaro z28 autoform
Transmission: Th700r4 automatic
Hey
My engine works fine , no fault code but after a 30 min drive the idle speed change from 600rpm to 1250 rpm The only «fault» i found is the electrical actuator on the carburator is active an push the speed arm I remove the wire to the actuator and the idel speed change to 600rpm. What is wrong ,and what do i need to replace. Looking forward to any advice
Cheers
Per Norway
Old Aug 9, 2019 | 06:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 3rdgen 305 engine engine running to fast on idle
IIRC, that solenoid is relay activated by the ECM, likely has something to do with the A/C being on.
RBob.
Old Aug 9, 2019 | 08:16 AM
palysell's Avatar
Which part of the A/C system does activate the solanaid on the carburator (switch ? Or sensor ?)
Please spesify and i will check it out
when the engine was running i does not use A/C But may have the fan running .i.e heating (it is low temp in Norway now9
Old Aug 10, 2019 | 11:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I have no idea if this diagram is correct or not. It looks like the throttle kicker is active on cold start until the ECM enables the relay. Which puts the idle kicker under control of the A/C system:
RBob.
Old Aug 12, 2019 | 01:10 PM
palysell's Avatar
I have now CHECKED And the reason for 1250 RPM IS use of A/C
thanks for your help RBOB
blackztpi
Feb 11, 2004 02:13 PM
Jurrel
Carburetors
Feb 1, 2003 02:13 PM
Chop_Top
Feb 19, 2002 07:11 PM
liquidinferno
Sep 28, 2001 11:21 PM
