Wideband on open headers question.
Old Aug 24, 2019 | 07:09 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
So the motor is all wired and ready to fire. Just waiting on fab guy to fit me in on exhaust. Might be a few weeks. I want to fire it but wondering on 02 readings with open headers. Wideband is 6 inches from end of collector. I can put a turn down on it to get another 4 or 5 inches. Would 10-12 inches after 02 be enough to get a stable reading? Cant just stick a length of pipe on it because collectors are set up for Vbands.Have a tune already in the dominator to seat the rings.
Old Aug 24, 2019 | 07:15 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: Wideband on open headers question.
Shouldn't be a problem. o2 is read all the time with a probe in the exhaust pipe. Roughly the same thing you have.
Old Aug 24, 2019 | 09:38 PM
GeneralDisorder's Avatar
Usually works fine but it might throw off idle readings. We sometimes get lean readings at idle if the wideband is too close to the exhaust exit from too much atmospheric oxygen.
Contrary to what you might think - catalytic converters have almost no effect on wideband sensors - especially at/near WOT. Another tip for you.
GD
Old Aug 27, 2019 | 09:58 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Would adding a turndown help at all? Fab guy is really tied up with alot of cars and I want to get this started. With a turndown like previously mentioned would extend the pipe to about 12 inches to the 02.
Old Aug 27, 2019 | 10:33 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
the only potential for inaccurate O2 readings would be if you had them hanging out the open, 6 inches keeps reversion air out at anything except idle, and only if you have a radical engine with a really rough idle will it make a huge difference there. The downturn might help in that case. heat should not be an issue with wideband...
Old Aug 28, 2019 | 08:34 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Thank you. I'm going to try the turn downs. Cam is only a 242/246 112 lobe. The thing I was worried about was the the motor was never fired. Seeing the fab guy is so booked I'm going to have to go this route . Thank you for all the imput.
antman89iroc
Oct 8, 2014 10:20 AM
87IROCZCamro
May 15, 2009 10:15 PM
klumb15
May 26, 2005 08:50 PM
MikeT 88IROC350
18
Apr 29, 2005 03:58 PM
