AE Filter, PW, and BPC Adjustments
Old Sep 21, 2019 | 08:53 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Chasing a lean spike on WOT have been adjusting AE Filters, AE PWs and BPC vs VAC values... Been back and forth a few times with little success so I'm wondering which values individually if any have the biggest affect on starting the AE event sooner?
Running 80# injectors @ 28psi with a vacuum reference FPR - 383 stroker, Renegade...
Old Sep 21, 2019 | 10:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AE Filter, PW, and BPC Adjustments
Delta TPS is first, as that is what responds fastest to throttle opening.
If you do a dump of the log file the last five columns prior to ADC channel data are devoted to helping tune in the AE.
RBob.
Old Sep 21, 2019 | 12:49 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
Thanks, been looking at those columns - for me now it's understanding the values. Will have to watch those AFR's closely as I'm tweaking it - some BIN errors were throwing me off. Found I couldn't copy values from Excel and paste em in to Tuner-pro.
Cartrax
Sep 17, 2019 12:20 PM
Cartrax
Sep 26, 2018 12:31 PM
85Iroc-Z
Jul 4, 2015 04:47 PM
liquidh8
49
May 8, 2008 09:40 AM
Ronny
Apr 18, 2007 02:06 PM
