EBL Flash Install MAP Sensor ?
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
I bought an EBL Flash w/Port Mod a few weeks ago. I had to get my car running perfect before I decided to put it in. The car is now running smooth with no SES codes now. I got a map sensor from the jy with the pigtail harness and vacuum line. My question is that my MAF has 5 wires and the MAP sensor has 3 wires? Which 3 MAF wires do I use and do I just isolate the remaining wires or do they go to something else for the EBL? My car is an 87 IROC, Auto, 5.7L. I'm planning on doing the install this weekend.
Car: check
Engine: check
Transmission: check
Re: EBL Flash Install MAP Sensor ?
RBob.
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
I have the same question. Could you PM me the short version on re-pin guide? And I PM you also my email address for the long form version.
