AE - MAP PW Settings
Old Sep 12, 2018 | 12:13 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Adjusting AE-MAP PW to cure lean spike (crossfire w/renegade) on WOT. I've reduced the values by 20% a few times already without any success. Must be other tables requiring adjustments. Suggestions?
Reading AE tuning is touchy. At the moment I'm just trying to get rid of that lean spike which is causing other issues. I assume I can finesse it more later as I come down this learning curve. Thanks.
Old Sep 12, 2018 | 12:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AE - MAP PW Settings
Need to add to the PW tables to add fuel. Or reduce the AE filter tables to add fuel and lengthen the duration of AE.
RBob.
Old Sep 12, 2018 | 01:13 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
Thanks. Perhaps that why is wasn't working. Must have misinterpreted this....
Old Sep 12, 2018 | 03:03 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Mr. RBob - thanks again! I adjusted the tables based on your comments and no more knocking. Feels like I just came down half the learning curve. Of course I was working against myself before. Running much better , so much I actually had a hard time controlling a standing start fish tail.
Old Sep 22, 2018 | 04:59 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Embarrassed to post this but knocks went away only temporarily - the next day they were back. Sounds crazy but sometimes it knocks other times under the same load and RPM conditions is doesn't . Also noted lean spikes actually never went away as I found spikes in the both logs on WOT. Knocks seem to occur a second or so after the lean AFR readings (btw knocking only noted after the lean spikes otherwise no knocking).
Doesn't look like AE. Adjusted and noticed AE kicks in immediately on WOT although it doesn't richen up for a good second or so. Then AFR's start going really rich - 9's 10's. That doesn't look like it needs more AE to me.
I figured I had fuel pump issues but after installing a new fuel pump and sending unit I'm still getting lean spikes and some knocks . Help, what else could causing these lean spikes?
Old Sep 23, 2018 | 09:01 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Here I am talking to myself again and starting to understand why. As I'm digging into similar posts I'm learning how complex it is to get this right. Finding even some of most knowledgeable folks here struggle with these settings. There is no pat answer and sometimes it's trial and error that works the best. I also realized I shouldn't just start replacing components without exhausting AE and VE tweaks.
I do have a request though and that is I would like to compare my VE and AE tables to anyone's with a similar setup (383, Renegade, 80# Inj, mild cam mod) who has successfully adjusted theirs. My knocking and lean spike occur at WOT between 1700 and 2500 RPMs at KPAs of 95+. That's where I'm going to start playing with the values again. If anyone would care to send me or post their tables for comparison I'm hoping it will give me some point to reference. You can PM for email....
Old Sep 23, 2018 | 09:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Be sure to keep enough fuel in the tank so that the pickup doesn't pull air. Another item is how much heat is in the engine. Do some pulls and the engine is going to build some heat, more then the first pull.
RBob.
Old Sep 24, 2018 | 08:34 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
Thanks for reply. Never let it get under 1/4 of a tank - old habit. It does get hotter but I don't think that's causing the issues. Something else is going on. It misses and records knocks like crazy now around 3600 RPMs and lower kpa's when revved in neutral. Not so much under load though... just the few noted at ~95-100 kpa's. Going back to some older bins I may have just hosed the current one into a FUBAR state or some other mechanical schtick going on.
Old Sep 25, 2018 | 06:15 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Latest adventure - no gas from injectors. Correction - occasionally get spurts on cold crank then they shut off but sometimes no spurts on cold crank. Fuel pressure is there and I'm getting oil pressure readings while cranking. Must be an intermittent short somewhere or the ECM is hosed correct? It's not throwing any codes...
Old Sep 26, 2018 | 12:31 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Hello sport fans, fixed was a loose connection at coil.
masteller
16
Oct 31, 2010 08:36 AM
Birdstheword
Jan 3, 2010 05:35 PM
90c350
Mar 10, 2008 02:35 PM
justme
37
Jul 10, 2003 12:21 AM
Dee
Sep 6, 2001 07:27 PM
