map map map map map !!!
Old Jan 2, 2010 | 09:01 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
so today fter adjusting my valves on the drivers side i noticed my map sensor was plugged in backwards . could this affect fuel distribution ? " because i have a rich running lo3 " now i remember that when i changes my module in the dizzy and plugged it in incorectly the car ran like crap , but thats fixed . i wonder if the map being plugged in wrong could be making my engine run rich ?
Old Jan 3, 2010 | 09:50 AM
Vader's Avatar
Re: map map map map map !!!
The connector should be keyed so that it cannot be plugged in backward. If the conneector is damaged and it is actually plugged in backward you would likely experience problems, and an error code.
Old Jan 3, 2010 | 05:35 PM
yeah , no codes in ecm and im still running rich . i even tried to run the engine with the the CTS unplugged and right away it flooded , so i plugged it back in . today i also put in a new o2 sensor and that didnt help . what else manages fuel distribution ither than the map sensor and o2 sensor ? also i have installed the msd street blaster coil and its too big to bolt down both sides of the coil . one side hits the intake runner so i only have one side bolted down and that is the side that bolts down with the throttle bracket . would this cause any ground problems thus giving me a weak spark and creating an incomplete burn ?
db057
Jan 10, 2020 08:55 PM
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
