ECU cooling fan signal
Old Dec 15, 2019 | 09:25 AM
Garreths's Avatar
Car: 1985 Z28 Camaro IROC-Z
Engine: 5.0 305 TPI
Hi guys, i accidently ran +12v switch power to the green wire with tracer from the ECU. is the signal wire a negative signal? if so would it have blown something inside the ECU? Car starts and runs fine, gauge works fine but now just after 220deg im not getting any voltage from that green wire with white tracer from the ECU. what is the chance that something small blew and i can repair it myself?
Old Dec 16, 2019 | 10:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECU cooling fan signal
It would be helpful to know which ECM this is. As for the ECM controlling the fan relay, it provides a ground to activate the relay. So connecting +12 volts to it can fry the driver if it was trying to turn on the fan relay.
RBob.
Old Dec 16, 2019 | 10:30 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Looking at his other posts I think it’s a 1226870 85 tpi ecm.
tcrisp
Feb 3, 2017 08:45 PM
89377STROKER
Nov 3, 2011 12:31 AM
brandonledski
Apr 5, 2009 12:20 AM
87SC/SS
Aug 18, 2003 08:07 AM
anagodadavida
Sep 23, 2002 12:32 PM
