Code 41 and 53 86 305 CCC
Old Jul 24, 2020 | 02:59 PM
Cramplehade's Avatar
Car: 86 Camaro Sport
Engine: 305 Q-Jet
Hi, recently i purchased an 86 Camaro sport with a 305 Q-jet, and it has been a blast. when I bought it, it had the check engine code for bad 02 sensor and bad map sensor, and I replaced those and the codes went away. for a few days now however, both codes 41, and 53 have popped up, and i'm not sure what exactly it means, since they both could mean many things. I suspect it may be a bad ecm or icm,because it seems to be running rich (bad gas mileage) and it will diesel at certain rpm, I am new to this car, but know how to work on vehicles, so if anyone could point me in the right direction of what to replace/diagnose, I'd be very thankful
P.S I forgot to mention it has an Edelbrock Performer intake and camshaft as well, I don't think that would effect the ecm, but just thought i'd share that.
Old Jul 29, 2020 | 02:13 AM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: Code 41 and 53 86 305 CCC
Code 41=Cylinder select error (Calibration setting does not match # of engine cylinders) or Faulty or incorrect MEMCAL. Generally an indication of a bad connection to ECM somewhere if car has been running.
Code 53=Voltage at ignition switch (battery) above 17.1v or lower than 8.0v.
Likely there is a less than solid connection to the ECM.
KnightRider499
Feb 23, 2015 06:29 AM
xbcrguy182x
Oct 3, 2006 06:17 PM
88fbird
Apr 7, 2006 09:19 PM
Nitsuj86Iroc
Oct 26, 2004 08:13 PM
formula91
Jun 6, 2003 10:25 PM
