Rough idle and code 44
Old Oct 1, 2006 | 06:37 PM
xbcrguy182x's Avatar
Hey everyone! Heres another little problem with my 86 firebird. When I first start the car in the day, it stumbles and dies out in 2 seconds. Start it back up, it stumbles, then revs a bit higher, then stumbles, then it revs up...etc..does this for like 30 seconds. Followed by rough idling. And now I get the SES light on and i scanned it and I got code 44. thats oxygen sensor-running lean. I just got the car 2 weeks ago and i did a tune up and changed the oil. the car was sitting for 5 months prior me buying it. Any suggestions on getting it to run more richer? thanks.
Old Oct 2, 2006 | 08:13 AM
Vader's Avatar
What engine is in this '86?
Old Oct 2, 2006 | 08:31 AM
Sorry for forgetting to mention it. Its the 2.8l v6.
Old Oct 2, 2006 | 03:52 PM
Update... I was browsing some sites and I came along one which gave more detail to this code...
44. Oxygen sensor lean
(Poor electrical connection, open or short in circuit; defective ESC module;
defective knock sensor; defective ECM.)
Anyone had experience with this code?
Old Oct 3, 2006 | 08:52 AM
Bump
Old Oct 3, 2006 | 09:44 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Sounds like one or more fuel injectors could be plugged from the car sitting for 5 months.
Old Oct 3, 2006 | 09:47 AM
ahh..should I try and pour in some fuel injector cleaner into my gas tank? Or do I have to take them out and clean them? If so, how would I clean them?
Old Oct 3, 2006 | 09:56 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Try the in-tank fuel injector cleaners first, with a tank full of good gas. You can not (or should not?) attempt to clean the injectors yourself. The other option would be to take the car to a shop that will clean the injectors on the car with a heavy duty solvent. Cost at a shop can be pretty expensive, anywhere from $75 (on sale) to the cost of a new set of injectors.
Use a good fuel injector cleaner. I've always used BG44K, but it's pricey (~$25).
Old Oct 3, 2006 | 10:09 AM
Cool thanks...could a dirty fuel filter also cause this to happen also?
Old Oct 3, 2006 | 10:28 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Yes.
Old Oct 3, 2006 | 06:17 PM
Update: I didnt touch anything in my car, but I started it today and it ran nice...no rough idle, no stumbling....this is interesting...
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
JHX
Aug 29, 2015 02:30 PM
