New Tunerpro RT plugin (aldl & WB)
Car: Firebird 1978
Engine: LQ9
Transmission: 4L65E
I created new plugin for my friend, so he can log ALDL + Wideband O2 from -89 TPI Firebird.
If anyone else want to test:
https://github.com/joukoy/Tunerpo-aldl-wb-plugin
All feedback is welcome.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: New Tunerpro RT plugin (aldl & WB)
Just curious how is this different from adding the wb signal to the ecm with arapwb or a channel with apu1 ?
Car: Firebird 1978
Engine: LQ9
Transmission: 4L65E
Just alternate method, if you dont have apu1 and/or dont want add new pin for analog signal to ecm (arapwb).
btw, adding support for Plx WB. Any volunteers for testing?
Car: Firebird 1978
Engine: LQ9
Transmission: 4L65E
This plugin reads WB data directly from WB controller/cauge using PC serial port => No A/D conversion, no need for apu1.
But, need another serial port, or serial-usb adapter + usb port (and another cable)
Engine: Lb9
Transmission: M20
Sounds easier to setup to connect to d8 of the 165 ecm.
https://www.thirdgen.org/forums/diy-...deband-o2.html
