Crazy intermittent no start- EBL
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Car won't start. No spark. Car will start and run for days, weeks or months then condition returns.
Can check sig for a lot of details.
EBL computer (don't believe it's the problem but relevant)
Basically "stock" ignition with remote coil and MSD 6AL
I can easily bypass MSD so I've tried it with and without box. When I manually ground the MSD trigger wire the coil will spark through the coil wire.
Replaced module in dizzy, cap and rotor. Ran for a few blocks (with MSD) then quit.
Bypassed the MSD same problem.
I'm wondering if the "ignition control module" on the firewall is a possible culprit. I've never changed it.
Any ideas is greatly appreciated.
Car: check
Engine: check
Transmission: check
Re: Crazy intermittent no start- EBL
Pickup coil in distributor is a likely culprit. If the unit on the firewall is a flat square box, that is the knock filter and won't prevent the ignition system from sparking.
RBob.
RBob.
Car: 89 IROC
Engine: 6.8 HSR N2O
Car: check
Engine: check
Transmission: check
Yes, should be between 900 and 1,000 ohms. But being intermittent it might pass the test and still be bad. Worst part of replacing the pickup coil is removing the distributor shaft. A can of carb gum cutter is helpful here.
RBob.
RBob.
Car: 89 IROC
Engine: 6.8 HSR N2O
