In-line Fuel Pump / ECM Fuse is Hot and Melts.
Old Jun 7, 2021 | 06:34 PM
jimmydz28's Avatar
Car: 1989 Camaro IROC-Z
I have an 89 Camaro IROC TPI 5 speed which is having an issue with a the in-line fuse melting and getting hot. I’ve had to change the fuse several times over the last several years of owning it. I never got down to the bottom of it. But now I want to focus on it because it could be leading to some other problems I’m having. What amperage should I have running through that wire??
Could this mean the fuel pump is going out?? I don’t really think it could be much else besides a bad corroded fuse holder or bad fuel pump. Just wanna know where I can start. Thanks.
Old Jun 7, 2021 | 07:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: In-line Fuel Pump / ECM Fuse is Hot and Melts.
How many amps is the pump drawing?
Old Jun 12, 2021 | 05:47 PM
jimmydz28's Avatar
I checked it this morning at the in line fuse…I’m getting 0.15 to 0.19 amps
voltage from the fuse to ground on battery is 14v
is there a spot in the engine I can check for the fuel pump? Or do I have to crawl under the tank???
Old Jun 12, 2021 | 08:28 PM
Engine: Lb9
Transmission: M20
You should be higher amperage than that, are you testing at the pump relay ?
Old Jun 12, 2021 | 09:16 PM
jimmydz28's Avatar
no I was testing at the in line fuse by the battery, I’ll have to check the fuel pump tomorrow and let you all know
Old Jun 13, 2021 | 12:40 PM
jimmydz28's Avatar
Okay so today I did more research. From what I gathered, it seems like the way to measure the fuel pump amperage is in fact the ecm/fuel pump in line fuse.. I’m getting less Than 1 amp yet my car is able to run.. I checked the amperage at every wire at the fuel pump relay while my car was running and still wasn’t getting 1 amp.
85Iroc-Z
Dec 25, 2011 07:55 AM
caseyZman
Nov 16, 2008 02:41 PM
mattkc
Jun 9, 2008 08:49 AM
91GTA350
Aug 11, 2004 12:02 AM
Kj Rockz
Jan 6, 2002 11:44 PM
