Fan switch temp sensor
Old Sep 17, 2021 | 03:09 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
If I have my radiator fan operating off of a toggle switch do I need the fan switch temp sensor between cylinders 6 & 8? Does the ECM use this for reference? The plug needs to be replaced and if I don't need it I'm not gonna replace it.
Old Sep 17, 2021 | 09:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fan switch temp sensor
ECM does NOT use the switch in the pass side head. ECM only operates the PRIMARY fan,... the ECM CTS (Coolant Temp Sensor) is where the ECM gets it's temp readings from.
The switch in the pass side head only controls the SECONDARY fan.
The switch in the pass side head it a "switched ground" circuit. In the past; ( usually because the switch fails ) I've seen it modified by people with a toggle switch by cutting the wire at the switch, adding wire to it and running the wire into the cockpit to a toggle switch,.... and running the other wire from the 2-way toggle switch to ground so the toggle switch sends the "switched ground signal rather than the switch in the head. The rest of the system ( relay, wiring, ect...) would still need to be intact and functional for this basic modification to work.
91banditt2
Sep 30, 2021 12:26 PM
Nonni
Jun 26, 2010 08:28 PM
Cornholio7979
May 3, 2006 05:28 PM
NXS055
May 8, 2002 07:42 PM
anesthes
Aug 14, 2001 11:00 PM
