wiring problems
Old May 28, 2022 | 10:12 PM
86 trans am 3rd's Avatar
wiring problems
so b4 my mom passed away 8 months ago she bought me a trans am that had a worn out engine in it but i didn't get to do a swap b4 she passed away on me so now im able to build it to what i like i pulled the old 5.0 tpi fuel injected engine out on my 1986 Pontiac trans am and i put a 1968 327 smc engine down in it with a carb and now i really don't know how to wire it up and be able to use the original dash cluster i want it as if i never did anything to it any help would do im trying to build this car in
remembrance of my mom and so i can pass it to my son when he grows up the pic at the bottom is what i had in it and the one on top is the one i put in it
Old May 29, 2022 | 04:16 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: wiring problems
Shouldn't be too hard. You can go thru the big firewall harness on the drivers side and find the wires for, coolant, oil pressure and tach. I can't remember how the Volt gauge works but I believe it comes thru the gauge power from the fuse box, not 100% sure on that
Old Jun 25, 2022 | 10:14 PM
Re: wiring problems
so is there any way i can take this whol intake off and put my tpi back on it will that do any damage i dont like the card
Old Jun 25, 2022 | 10:20 PM
Re: wiring problems
dose anyone know if i can take the tpi off the old motor and add it on the 327 and it run right
Old Jun 26, 2022 | 07:53 AM
thatsupnow's Avatar
Re: wiring problems
That shouldn't be a problem but you'd need a custom chip for it to run perfect
JoeMonte
Dec 26, 2016 09:59 AM
jim mcgrew
Mar 9, 2016 08:49 PM
Reddeath210
Sep 26, 2014 11:09 AM
noahTHEpurdy
Dec 28, 2006 11:23 AM
fbody-tom
Apr 24, 2006 05:06 AM
