how do you hook up pcv on a F/I throttle body
Old Jan 19, 2002 | 08:59 PM
DavidR's Avatar
I've got it hooked to a 1/2" port on the upper right hand side of the regular old GM style throttle body on advice from another forum but I can't feel any vacuum at this port. I don't think it's pulling any vac on the motor. Is this the right port? Somebody got a pic of the correct setup? It would be like an L98 motor I think.
David
Old Jan 20, 2002 | 08:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: how do you hook up pcv on a F/I throttle body
David
well the PCV valve hooks to a vacuum port betwwen the driver's side runners. the other line coming from the passenger vavle cover goes to the TB on the passenger side.
Old Jan 21, 2002 | 04:06 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
What happens if you replace the pass side tube with a breather and just plug the hole on the TB would it cause vaccuum trouble?
Ken
Old Jan 23, 2002 | 01:03 PM
DavidR's Avatar
plugging T/B port
mrr23:
Thanks, I had the drivers side on wrong.
ChevyKen:
I was thinking about plugging the port on the T/B AND the hole in the passenger side valve cover and running with vacuum on the motor. I think old 280z's had a setup like that. No breather, just vacuum being pulled on the motor to pull out blow-by gasses. Maybe someone here with a 280z can set us straight or fill us in on the pro's/con's of running with vacuum but no air inlet thru a breather.
dr
Old Feb 6, 2002 | 10:11 PM
D144John's Avatar
You cannot run only vacuum to the engine without a relief breather somewhere,the engine will start leaking oil from the front and rear main seals.
Even though some cars may appear to have only a vacuum hose running to them,every car has to have some form of vent to the crankcase to keep the engine from pulling a vacuum under the pistons.Look close on that 280z and you'll find a hose going to the air box that lets the engine "breath".
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
hayesaw0210
Aug 23, 2015 11:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
