1990 GMC OBS 5.7 TBI swap to 5.7 vortec
Old May 3, 2023 | 06:28 PM
GMC5.7's Avatar
Car: Gmc
Engine: 5.7 Vortec
Hello , I have recently swapped my 5.7 tbi to a Vortec 5.7 . I知 trying to keep old wiring harness and computer but I知 not sure if harristuning is still pretty decent with his work . Is there any other recommendations that someone can lead me to .
Old May 3, 2023 | 09:47 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 1990 GMC OBS 5.7 TBI swap to 5.7 vortec
You will likely get better answers at gmt400.com. Black bear is mentioned often there, don't know anything about them myself.
Old May 3, 2023 | 11:11 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
You should do a search for tuning companies that have positive/negative reviews. Not sure of which year vortec 5.7 you're referring to. I've done a '92 OBS TBI 350 and swapped to vortec heads/intake retaining the TBI unit w adapter. I tossed a L98 roller cam in there as well. Main thing with the tuning was using an appropriate spark map that closely matched an LT1 which has similar head flow characteristics. Good luck!!!
Old May 5, 2023 | 11:57 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Probably run decent by just bumping fuel pressure up to 16-18lbs. You may have to get a different fuel pump to support that though because TBI pumps only put out 11-15psi.
Camarohero2012
Dec 29, 2012 03:45 PM
wickedtrucking
Jan 5, 2012 05:25 PM
v10viper04
Nov 8, 2007 10:48 PM
LottaBallsCamaro
Mar 14, 2002 11:10 PM
