Datlog and Ve Learn
Datlog and Ve Learn
Hi,
I have a ebl flash 4 ECM and I am using the WUD app. My questions is can you record a datalog and a VE learn at the same time? Is it as simple as selecting Datalog and the VE learn under the File drop down?
Dan
Dan
Re: Datlog and Ve Learn
RBob, so you can drive around and VE Learn for a while... then pull over to the side of the road and push a button to update the VE tables, then keep driving?
And it can all be done with the engine still running?
Transmission: T-5, TH350, T-5
Clearly Rbob can tell me something about it that I don't know but as far as I know you have to shut if off to reflash to then start it back up and go. At least that's how I've always done it.
Car: check
Engine: check
Transmission: check
When the ECM is flashed it goes into limp mode. So it depends up the CALPAK to run the fueling. Spark advance reverts to base (at idle). Once the flashing has completed (a few seconds), the ECM resets and resumes full control.
If there isn't a CALPAK in place, upon flashing the ECM shuts off the injectors and the engine stops running. Not a big deal, once flashing is done just tap the key to restart. This is how I do it, as it is a clean shut down of the engine. And no need to key-off, then on to flash.
The EBL list with CALPAKs and such:
EBL Classic, stock GM CALPAK installed.
EBL Flash, stock GM CALPAK installed.
EBL Flash-II, no CALPAK and no provision to add one.
EBL P4 & SFI-6, place on board to add a MEMCAL for the CALPAK. Not provided, needs to be added by user. Can also provide for a knock filter.
The sticky wicket part of this, along with why the CALPAK was eliminated in the EBL Flash-II, is that unless the CALPAK is calibrated for the engine and injector flow, fouled plugs can result. Which is a lot worse then just needing to tap the key to restart. And 99.9% of the folks using an EBL system have modified engines.
Note that the CALPAK is nothing more then a bunch of resistors. So it is easy to physically re-calibrate. But the need for at least a way to measure the injector PW (o-scope), doesn't make it entirely easy.
RBob.
