To change to aftermarket or not?
Old Mar 30, 2024 | 08:28 AM
Makeitreal81's Avatar
So I have a 91 tbi rs auto. I'm trying to figure out what to do with my ecu eventually I plan on upgrading the engine, but atm it has issues that a tune would solve. Egr is screwed along with timing being wocky and not having a way to see what's going on. I'd like to use the shitty stock ecu, but the prom isn't 28 pin and when I tried to use the adaptor it wouldn't work (likely my fault). That being said if anyone knows where I could find the software to use my stock ecu I'd try it again, but a part of me is like just get a megasquirt or holley kit and be done with it! Heck I even thought about going to a carb, but that presents its own issues. Like lock up torque converter, kick down and the engine timing. I'm kind of at a lose anyone I'm looking for advise.
Old Mar 30, 2024 | 01:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: To change to aftermarket or not?
There is a solder in conversion adapter to go from 24 to 28 pin at
https://boostednw.com/GM2-adapter-G2...=Moates&page=2
$61 mask software at tunercat or tunerpro.
Old Mar 30, 2024 | 01:21 PM
I have that and the booster. Idk if I used that mask or not. Fyi I did tune my son's 88 tpi with the Australian tune I don't remember what the tune is called, but it was well worth the move over to that tune! I'll take a look at the mask I used later today.
Old Mar 30, 2024 | 01:29 PM
Engine: Lb9
Transmission: M20
The 1227165 to 12p is a totally different animal. The 1228746 is $61
Old Jul 13, 2024 | 07:30 AM
dirk courage's Avatar
how do I get an after ket EcM the O-2 died on me, unless there is another way to bypass that, help me please!!!!!!!!!
Old Jul 13, 2024 | 07:47 AM
Engine: Lb9
Transmission: M20
English please !
tbakertrucks
Sep 29, 2019 03:07 PM
91GTABird
Jan 16, 2006 09:39 PM
BronYrAur
Jan 8, 2004 01:37 AM
dimented24x7
Oct 29, 2003 12:37 PM
IROCKER
Feb 26, 2003 03:00 PM
