Win ALDL help... explanations...
Old Jan 25, 2002 | 03:03 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I just got done running my car with the WinALDL program. I collected a little bit of data, but I don't really understand too much of it. I need to get a new chip burned, but I don't quite understand the data. Also, I think that some of my sensors and things are out of adjustment, but I don't know where they should be.
I checked around on all the sites that everyone has recommended, but I don't quite understand it all...
Any help would be awesome,
Thanks,
Mike
Old Jan 25, 2002 | 03:34 PM
burntblues's Avatar
Car: 1989 Camaro RS
heres the file attachment with the info...
I had to take a bunch of the numbers out because of size, but it was starting to look pretty repetitive.
Thanks,
Mike
File Type: txt
Old Jan 29, 2002 | 10:14 PM
burntblues's Avatar
Car: 1989 Camaro RS
anyone?
All help appreciated,
Thanks,
Mike
Old Jan 31, 2002 | 02:03 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
You need to go to the PROM board with these Questions. I am sure they can help you. The guy that wrote Winaldl is over there.
Old Feb 4, 2002 | 06:13 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm assuming you have TBI because of the caprice 350 eprom in your sig. That's also telling me you're running an 8746 ecm. Either post this on the TBI or DIY-PROM board. I saved your data and looked it over, but you need to post this on another board or as a moderator to move the topic.
Old Feb 4, 2002 | 06:29 PM
burntblues's Avatar
Car: 1989 Camaro RS
Thanks man, I already moved it over to the DIY board.
-=-Mike
Hotrodboba400
Dec 10, 2019 07:07 PM
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
