Different types of ECM
Old Mar 2, 2002 | 03:07 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I am considering swapping a TPI from an 85 F-body to my 86 T/A. I have heard that the 85 unit is not a good one, I should find me an 87-89 ECM.
1) Is it the same unit from 87-89?
2) What is the number of that ECM?
3) Why is the 85 ECM so bad?
Thanks in advange,
Nonni
Old Mar 2, 2002 | 08:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Different types of ECM
Thanks in advange,
Nonni
The 85 was a rather crude system. It was the first year, not that it''s really bad, just that it's dated. Also the refresh rate for scanning is slow.
For the work involved, I'd say use the 90-92 ecm and switch to the MAP system. That's a 1227730. Long term you'll be happier with it. MAF sensor $150 MAP $50, one bad MAF pays for the swap.
Old Mar 3, 2002 | 07:19 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I thought that it would be better to use MAF system on my car since it is an 86 T/A and I am working on an old 350. What will I gain if I use Speed density system?
Nonni
Old Mar 5, 2002 | 01:31 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Nonni
Better self diagnostics.
Faster ALDL stream.
Better data logging if you get to that stage.
A full generation newer of ecm design (almost 10 years newer).
Lots easier to program.
Easier to find replacements.
Like I said the MAP sensor is 50 vs $150 for your's, and I would be surprised to see the MAFs becoming harder to even find.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
