Speed density conversion
Old Mar 20, 2002 | 11:56 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I have a 1987 350 TPI MAF with a 1227165 ECM. What is involved with changing over to speed density ? I know the ECM will have to be changed & the MAF removed & MAP added, but what else ? Especially the wiring. Can the existing harness be repinned? What about wiring the MAP ? Thanks in advance.
Old Mar 20, 2002 | 12:51 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: Speed density conversion
Go here:
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
and soak it all in. There are 2 ways of doing it: re-pinning the wiring harness, or making an adapter so that you could switch back and forth between MAF and MAP.
Old Mar 20, 2002 | 07:51 PM
Ricktpi's Avatar
Thanks, Greg.
LittleFranks
Oct 7, 2015 11:26 PM
85 Jimmy
Sep 30, 2015 07:56 AM
adelane
Sep 9, 2015 08:51 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
