still not connecting to the ecu
Old Mar 24, 2002 | 03:56 AM
nice3rdgenz's Avatar
i have had the computer sent off to accel and the data cable both are good, yet the laptop has still failed to connect to the car..any hints or help??? i have been told that the laptop may be to good for the program..it is a 133MHz with windows 98..any help would be great..
Old Mar 24, 2002 | 08:30 AM
88IROCZ350's Avatar
Yes, what you have been told is correct. The Calmap software does not like to run on windows 98, i found that out the hard way also. I pluged a windows 95 computer in and bam, showed up instantly. If you can i would just take 98 off of your computer and put 95 on it. I have also been told about a program called partition magic, it supposivly will alow u to use calmap and other older DOS programs with 98, ME, 2000. HTH
Old Mar 25, 2002 | 12:11 AM
so do u think i should just put win 95 on there and it will work?? cause i already kinda wiped off win98
Old Mar 25, 2002 | 04:56 PM
88IROCZ350's Avatar
yes i believe it would, i'm just using a standard windows 95 ibm laptop and it works fine.
Old Mar 27, 2002 | 02:58 PM
87Z-ya's Avatar
Find a 486 with win 95 off ebay or somthin for cheap. That way you dont care if someone rips it off either.
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
