Maf to MAP prom help..w/in
Old Apr 16, 2002 | 09:13 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Would I need to change a stock 92 prom for use in a converted MAP setup....?? Im trying to switch to a map setup BUT I dont have Vats....So will I have to burn a chip that will shut vats off?? Is it possible...Necessary??
Old Apr 16, 2002 | 10:12 PM
Brent's Avatar
You will need to turn off VATS in the 92 EPROM or make a signal generator that simulates the VATS signal.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
racereese
Oct 3, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
