Desired idle and settin rpn in field service/park
Old Apr 20, 2002 | 11:40 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If my commanded idle is 800 rpm in drive , what should i set the base idle at when adjusting the tbplates in field service mode?
on stock its 650 in P should = 450 in D
If im going for 800 in D does that correlate to setting it at 1000rpm? seems high to me havent tride going 200rpm over yet and seeing what happens
setting it as low as the motor will idle at hot , right around 700 or so it seems to hunt around a lot iac wise and eventually end up with iac counts from 70-90 in gear at a lite with the idle at about 750-800 rpm
lemme know :-(
jeremy
Old Apr 21, 2002 | 10:32 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I actually prefer my "Drive" and "Park" idle speed to be the same. I find it makes it smoother to shift the tranny from "Park/Reverse?Neutral/Drive".
I can't say with your ECM but on 165s and 730s, there is a "Constant" of the amount of RPM to add when in "Park/Neutral". Stock is 100 rpm. I found that extra 100 rpm really made a bad "CLUNK" when I shifted my tranny from "PRND".
That's why I don't add any extra rpm now.
Old Apr 21, 2002 | 05:01 PM
3.8TransAM's Avatar
lol glenn all my tuning questions in here for now aply to my 91 formula 350 :-) Once i get it sorted out i may attempt tweaking the tta but not till then :-)
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Stroopwafel
Sep 11, 2015 06:38 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
scottmoyer
Sep 7, 2015 07:06 PM
