Injector flow rate differences in SD vs. MAF
Old Apr 29, 2002 | 08:40 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am burning a chip for my new SD ECM I am installing in a week. I am switching from MAF to SD. In the AUJP bin the injector flow rate is 22.1 #/HR but in my stock MAF chip and in the ARAP MAF chip the injector flow rate is 22.4 #/HR. Should I leave it set to 22.1 in the AUJP bin or should I set it to 22.4?
Old Apr 29, 2002 | 09:01 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
In all honesty ... it doesn't matter. Seriously. Fact is - you'll have to change the VE tables anyhow once you get everything working. I say to just keep these two things in mind:
1) Know why you want to change something before you change it. The AUJP is a good base to start off with so go with those values unless you have a reason to change something.
2) You are going to have to make fueling changes anyhow in order to dial in the VE curves. The 0.3 variation isn't that big of a deal given that you are going to have to make changes anyhow ... its also not that big of a deal given how fuel pressure changes affect fueling You can unknowingly do much more change with a AFPR than with a 0.3 change in the constant.
Long story short? Stick with stock AUJP values unless you have a reason to change them.
Tim
customblackbird
Aug 15, 2021 10:16 PM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
mdtoren
Aug 16, 2015 05:45 PM
tmellott89
Aug 16, 2015 02:58 PM
