Some Questions
Old May 7, 2002 | 01:50 AM
86 IROCZ28's Avatar
Some Questions
I finally got around to getting my BIN file dump off my stock 1992 chip at school.
I got home and compared the values off somebody elses 305 dump and they are totally different. I am using WinBin and it does sometimes automatically close and says some error but I don't thik that the bug is displaying incorrect values.
For instance 400 RPM & 100kPa is displaying 11.95 spark advance
The screen dump on this forum of the same chip (not sure if auto or manual might play a role?) well on that screen dump at the same load and RPM was 0 spark advance.
Pretty much all the values are slihtly off and in some instances like above are way off. Which of the 2 spark advances sounds more right? I am just starting hence the stupid question.
If anyone else is using WinBin I have had a look thorugh the values table and see some strange values.
Like the Engine size liters
RawHEX Litres
8B .2
Anyone know what is up with that. I have a 5 liter so should it not show 5 litres?
Mike
Old May 7, 2002 | 11:50 AM
tpi_roc's Avatar
Just to cover bases
With winbin make sure you set it to "Show In Calculated Values"
Old May 7, 2002 | 09:38 PM
86 IROCZ28's Avatar
I figured it out why the incorrect values were showing.
I was using WinBin V0.14 and using a V.011 ECU file!
I have gone back to WinBin V0.11 and it works perfectly.
Anyone by any chance know if there is an updated V0.14 ECU file for WinBin V0.14 around?
Mike
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
