Ruined memcal, WHat to do?
Old May 9, 2002 | 10:59 AM
87ColdAirIroc-Z's Avatar
Ok, i had a ZIF socket in my memcal but the ZIF broke (it was a lever type and did not fit length wise so i ground a little plastic off one end that is why it broke). I was going to install a new one and solder it on, that way i could leave it sit up higher and not have to remove plastic from it. I spent 2 hours soldering it initially and it did not work, fans came on immidately. I spent another 3 hours trying to get all connections and have no connections touching but could not do it.
Now my memcal is ruined. I know i can get a new one from GMpartsdirect.com for about $50. I do like burning chips but am not willing to sacrifice another memcal. I followed Traxions instructions on removing the chip and soldering on a ZIF socket very carefully.
Would anyone be willing to make me a memcal that i can easily replace the chip on (ZIF in place of chip)? If you give me a reasonable price to do it i can send you a check or what ever you prefer.
Or if some one has a Jet type adapter for sale i would be interested in that also. This would be preferred as i could retain the stock memcal w/o modification
thanks,
jake
Old May 9, 2002 | 12:27 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Check out my adapter, it should set you up. Even in the EPROM-end of your Memcal is mutilated, you should still be in good shape.
http://ice.prohosting.com/moates/gmecm/hardware.htm
-Craig
Old May 9, 2002 | 01:26 PM
Thanks Craig it looks great, even better than what i was looking for, expect an order from me shortly.
thanks
Jake
88SS6SPEED
Nov 11, 2015 07:05 AM
evilstuie
Sep 24, 2015 02:31 AM
lethaldomestics
Sep 21, 2015 01:18 PM
RyanJB
Sep 2, 2015 01:27 PM
