adapter needed??
Old May 14, 2002 | 08:42 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
adapter needed??
Ok, this might be a really dumb question, but is there an adapter needed to plug the Eprom into the pocket programmer? Where and how much is this bad boy?
The pocket programmers socket looks sort of like this:
- - (totaling something like 30(?))
while the plastic carrier that the chip is soldered to looks like this
Any help is greatly appreciated, I really want to start this stuff soon...
Thanks,
Mike
Old May 14, 2002 | 11:11 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
You're good, the chip (if you're talking about a chip outside the Memcal carrier) should go right in. The Pocket Programmer, when the lever is set straight, will 'clamp' down on the legs of the chip...
Old May 15, 2002 | 08:22 AM
burntblues's Avatar
Car: 1989 Camaro RS
but what about if its in the memcal carrier, I'd like to get a copy of the file used in the car currently. Also, is that where I would need one of the adapters that I saw you were selling later to plug my burned prom into the car?
I'm using the caprice chip and I downloaded the .bin file for it off of Jprevost's site, so I think I may have that part already.
Thanks,
Mike
Old May 16, 2002 | 01:43 PM
burntblues's Avatar
Car: 1989 Camaro RS
back to the top
Old May 16, 2002 | 03:56 PM
Brent's Avatar
If you are talking about a TBI EPROM, you need to remove the EPROM from the plastic carrier before you can put it in the programmer.
The first time you pop the EPROM out it will be a PITA.
I squeeze the carrier so the EPROM legs get pushed in towards each other. Then I push on the bottom of the EPROM a little. It should move easily. Then gently pry the sides of the carrier back and the legs should pop free.
Don't use much force on the carrier or you will bust it.
It just snaps back in place when you are done programming it.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Elliswon
Aug 10, 2015 12:33 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
