Same gps but different Cell # and different BLM?
Old May 19, 2002 | 01:05 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have some question for MAF experts.
After reviewing data from a long run, i noticed that at the same/very close gps., the Cell Numbers would be different thus giving me different BLM.
For example;
gps cell# BLM LV8 RPM
7.9 6 134 32 1200
7.8 1 119 40 950
So lets say that i want to adjust MAF in relation to cell #1. So when I do that, cell #6 would be out of range, woudn't it?
How are the MAF guys coping with this? Is there a way to adjust that?
Thanks.
Old May 19, 2002 | 12:04 PM
kvu's Avatar
kvu
From what I understand,you will need to make changes in the main spark table.If your rpms is 1200 and the load value is 32 then you will need to change the spark advance @ 1200rpm X lv8 32.Increase the spark to lean decrease the spark to richen.Use only small amounts of advance +-.I am not an expert though and you should use caution when changing the s/a.
Old May 19, 2002 | 04:40 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Same gps but different Cell # and different BLM?
For example;
7.9 6 134 32 1200
7.8 1 119 40 950
Personally, I ignore worring about which cell I'm in.
In you case you just need to tal a lil fuel out at 950 rpm, I'd try taking some of the voltage correction out. If you working in hex try taking a value of 0A out of 12-15 volts.
Old May 19, 2002 | 06:38 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Thanks guys.
I appreciate your help.
Old May 20, 2002 | 01:46 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
For example;
7.9 6 134 32 1200
7.8 1 119 40 950
Thanks.
As Grumpy said, ignore the BL cell number. The BL cell boundaries have a hysteresis to them, IOW, they overlap a little. I think in the ARAP bin, the hystereses (plural) are 100 rpm and 2 grams/second.
You'll need to adjust the values in MAF table #1 that border the airflow above. Unless your alternator is weak and your voltage drops at lower rpms, you shouldn't need to mess with the battery voltage correction table.
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
3.8TransAM
Sep 27, 2015 08:37 PM
ULTM8Z
Sep 16, 2015 09:15 AM
