What kind of PROM changes should I make?
Old May 21, 2002 | 11:04 AM
formul8!!'s Avatar
Car: 2004 GTO
I installed a 52mm throttle body with a hypertech airfoil, and it has seemed to lost some power.
My combo is:
-AS&M large tube runners
-fully ported plenum
-Edelbrock manifold
-SLP CAI
-modified maf
-SLP cat back exhaust
-24# matched injectors w/AFPR
-10" non-lockup 2500 stall converter
-stock 3.27 gear
-Stock heads,cam,exhaust manifolds
I do have SLP 1 3/4 headers in the garage waiting to be installed. I adjusted the TPS and IAC. Timing is at 12 degrees.
I am thinking there is too much air coming in and not enough flow for it to come out.
I'll be going to the track this week. I did not get another baseline with the new mods with the 48mm T/B.
I plan on getting AFR 190 heads and a cam next winter. I am trying to do things now so I don't to make more changes later.
Any input?
Thanks!
Old May 21, 2002 | 11:35 AM
cfabe's Avatar
Definately your exhaust is a huge limiting factor. Good choice on the SLP headers, I hope you'll be installing a catback with them. Have you made any changes to the prom at all or are you still running completely stock?
Old May 21, 2002 | 12:11 PM
formul8!!'s Avatar
Car: 2004 GTO
I have the SLP catback already. I'm still running the stock PROM. I used to have an SLP stage 2 chip,but I took it out and lost it.
The headers are going in next month. I have to get them Jet-Hot coated first.
Old May 21, 2002 | 07:23 PM
CHOANER's Avatar
Do you have a scanner?
If you do look at your "knock retard" I would guess w/12 degrees
initial on a stock prom you are probably getting detonation
retard causing you to lose HP.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
novaderrik
Aug 10, 2015 12:44 PM
