help getting BLM's stable
Old May 21, 2002 | 07:50 PM
CHOANER's Avatar
I have gotten my blm's in the ball park using injector constants
and maf table 1 for getting idle @ 128.
and have gotten driving blms pretty close 124-132 but where do i go from here? driving at light throttle and light load my blms are 127-130 but once i get under more load like a hill i start to go rich. do i want to work w/the maf tables in those ranges or do i want to use timing ? or is there a table im not seeing?
Thanks for any help..
87 T/A 355,MINI RAM,CANFIELD HEADS,ZZ9 CAM,SLP HEADERS,
FLOWMASTER,373'S,6AL.
Old May 22, 2002 | 01:06 AM
drive it's Avatar
How rich are you going???? GM's "spec" was +/- 4 or 6 BLM. Also if the majority of the maf gps readings are rich (eg- if "under load" gps from 40 to 150 or so) then I would adjust the inj. constant again to lean it and then richen the other areas.
As for using timing-any knock retard now?
Old May 22, 2002 | 05:31 PM
CHOANER's Avatar
Well the load range around 40-110 are good but beyond that is where it becomes richer sometimes as low as 112. as far as knock
i get none in the driving range, some wot but im working on that
got full advance comming in at 3200 and at 35 degrees total-
been lowering 1 degree till knock is gone and that seems to be the magic ##.
How do i lean out a higher load ranges -lower rpm w/out affecting the lower load ranges? through maf table?
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
BWilcox
Sep 20, 2015 12:19 PM
ULTM8Z
Sep 16, 2015 09:15 AM
CORV3TT3
Aug 23, 2015 11:26 AM
