6870 Ecm Bin
Old Jun 10, 2002 | 09:04 PM
mimgq2's Avatar
6870 Ecm Bin
I have 1985 vette with the 6870 ECM. I am going to convert this ECM in the winter. For the summer I would like to drive the car that just took me 9 months to build the motor. Its a 400 bored to 415 with a TPIS miniram and the ZZ-409 cam. 6" rods and AFR heads ported. It has 11:1 compression and 3" full exhaust and 1.75 headers. I need help with the prom. It appears there is no injector constant. I need to play with the pulse width. Is this correct? I ran the ALDS scanner and it tells me the car is now too rich. The BLMs are in the 108 range. With this what should I be touching. Is the pulse width the correct adjustment or am I missing the boat. It went rich because the chip was custom for a wild 350 with #24 injectors. I bumped the injectors to #30 for this new motor. The fuel pressure is 49lbs. Also does anyone have anything I can baseline my definition file with? Finally I have not played with WOT. I am told that WOT is open loop and I see two tables for that. Any comments
Frank
Old Jun 10, 2002 | 10:54 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I was in the same boat as you with my 85 camaro TPI 415 and I just took the 30#'s out, put the 24#'s in and called her good until winter and had alot of fun whoopin A$$ and the BLM came into reasonable and the A/F gauge said she was good to go
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
