injector cleaning
Old Jun 18, 2002 | 09:47 PM
goneracin's Avatar
injector cleaning
Anyone know of or can recommend a good place to have my stock injectors cleaned and flowed?? Or is it worth it or not? Im beginning to think my idle problems may have something to do with 90,000 miles and 15 years of "gunk" and use. Also, whats this service usually cost? Thanks
Bob
Old Jun 19, 2002 | 03:44 AM
86 IROCZ28's Avatar
Before you go all out and spend some $$$ on getting the injectors cleaned I would do a few things 1st.
Check timing
Check plugs
Check IAC (remove and clean) then set TPS and Minimum air.
Put some injector cleaner into fuel tank
See if that helps, you might fix the problem and save $$$
Old Jun 19, 2002 | 09:12 AM
kvu's Avatar
kvu
I bougt 30 lb accel injectors for $250 new so keep that in mind.Accel has good prices on injectors through summit.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
