Too many knocks during certain RPM. We cant fix it
Old Jul 8, 2002 | 10:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My friend and I are having trouble burning a chip. We are running into 1 problem. I recently intalled tf heads and a 218/224 cam on an 89 TPI. We have the blms perfect , but from a stand still and taking off to 5000 we are getting 1-2 knocks. but while driving at 40 and nailing it the car downshifts to 3000 and I am getting 15 knocks. The car will scream and go nowhere until about 4500 then it'll catch up. o2 readings are int he 950 range during WOT. any suggs?
Old Jul 9, 2002 | 02:51 AM
drive it's Avatar
Re: Too many knocks during certain RPM. We cant fix it
Just to clarify....you say 15 knocks-you mean 15 degrees of knock???? How much advance do you have programmed now? Any advance in the wot table added?
I also have the tf heads and have found that it doesn't want all that much timing! Also try to give it cooler intake air-that can make a big diff too.
Old Jul 9, 2002 | 10:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
15 degrees of knock with the stock chip. with custom chip its still at 15 with no spark advance. (something like that) this is with 10* timing. car has no power , but if i move my base upto 14* i get lots more power and still 15 ddegrees of knock.
Old Jul 10, 2002 | 09:04 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
my bad. we have spark advance int eh range of 28-30. I only get 15 or more counts at downshift.
Old Jul 13, 2002 | 11:08 AM
funstick's Avatar
chekc yr vavle lash. i don't know the details of yr setup but the new heads thing is a tip off. most likely if you don't have to much advance a mechanical noise could be triggering the knock sensor.
i would check yr vavle lash and cam end play. check the lash first don't be surprised if you have a few clatery rockers. good luck.
92firebirdguy
Sep 1, 2016 07:53 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
