8d Calibration question
Old Jul 12, 2002 | 01:14 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
At what address is the Shift light RPM stored at?
My Tuner Cat TDF does not have a setting to change it
EDIT
I found this..
This is the info I have:
LC290: FCB 128 ; 56C, (132f) COOL THRES FOR L.U.
; OR SHIFT LIGHT
; E LIGHT PARAMS
LC2ED: FCB 120 ; 50C, (122F) MIN FOR LIGHT ENABLE
LC2EE: FCB 47 ; 47 MPH MIN FOR LIGHT ENABLE
LC2EF: FCB 0 ; 0 TPS MIN FOR LIGHT ON
LC2F0: FCB 0 ; 0 LV8 MIN FOR LIGHT ON
LC2F1: FCB 56 ; 1400 RPM THRES FOR LIGHT
LC2F2: FCB 208 ; 5200 RPM FORCE LIGHT ON
so it should work
Old Jul 13, 2002 | 07:37 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Those codes are for the MAF bin, not SD $8D. Go get the $8D hack from ECM GUY's website.
Old Jul 13, 2002 | 07:53 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
I have it, but could not find the Shift Light info. Does not matter anyway, I found my Cluster does not have a shift light on it
Old Jul 13, 2002 | 08:55 PM
Car: Death Mobile
Engine: 666 c.i.
Do a search on "Light" and "Lite", it should pop up.
A while back I attempted to make my shift light work on my L98 - I even FORCED it with a code change. But it would not come on.
I believe there isn't even a wire lead off the connector for the shift light (separate pin for Manuals off the 7730 ECM vs Auto).
On MAF cars, autos and manuials use the saem wire lead but your harness is then either wired to the Shift Light if it's a manual or to the TCC if it's an auto.
When I get a chance to look at my harness, I will confirm whether there is even a wire lead for the shift light for an auto car. But somewhere in my travels, I recall that there is not.
This is another reason to start with a 305 5-speed rather than a 350 auto car if you goal is to have a "big inch" manual tranny car. The 305 5-speed is already set up properly, right down to the Shift Light.
Old Jul 13, 2002 | 09:15 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
You know, I just realized.. I never said it was for a Corvette with the 7727.. I am not worried about it. like I said there is no Stock shift light on the Cluster
Old Dec 13, 2003 | 07:24 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think this is right for $8D
A3 = Force light on, stock = 3125 ?
B3 = Min rpm for 1st gear shift light, stock = 2700
C5 = Min rpm for 2nd gear shift light, stock = 1575
D7 = Min rpm for 3rd gear shift light, stock = 2200
E9 = Min rpm for 4th gear shift light, stock = 2075
-- Joe
Eric2ndGen
Nov 5, 2015 01:51 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
