TCC lockup question
Old Jul 31, 2002 | 03:33 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
TCC lockup question
Hey.....switched from 86MAF and now have SD. As you know the speedo is cable driven and I do not have a VSS so even when my car is moving it registers at 0 mph in the ecm, and the converter never locks up. In Tunercats there is a place to lock up the converter at a certain rpm instead of mph, but I could not find the place to set the rpm for it to lock. How can I get it to lock up?
Chris
Old Aug 2, 2002 | 12:31 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Do I need to give more info?
Chris
Old Aug 2, 2002 | 05:33 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
First-Forget about the RPM thing.
Second- You do have a VSS, it is in the instrament cluster.
Third- Did you follow Mike Davis's tech page when you swapped to speed density? If you did you would have seen that the prom must be modified for VSS to work. The "mag speed sensor installed" switch will have to be un-checked.
Old Aug 6, 2002 | 10:48 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
That is not an option on the version of Tunercats that I have, how do I get it?
Chris
Old Aug 6, 2002 | 09:34 PM
Engine: 4.0L
I have heard that the latest version of $8D has it.
jklein337
Sep 19, 2018 06:23 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
redmaroz
Aug 16, 2015 11:40 PM
