Pocket Programer/29C256 question
Old Aug 6, 2002 | 01:37 PM
TPI K5's Avatar
On the 29256 PROM, there is an arrow on top in the corner. Which way should that arrow face in the programer and also in the memcal? I just wanted to make sure before I messed something up thanks
Old Aug 6, 2002 | 03:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Pocket Programer/29C256 question
Arrow I don't know.
Usually there is a scallop on one side. It should match the sketch on the programmer. On the memcal the scallop should face the center. Might call it a C
edge C edge
Old Aug 6, 2002 | 04:09 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
It faces toward the handle on the programmer(foward) and away from the handle on a Craig Moates adapter.
Chris(had the same question)
Old Aug 6, 2002 | 04:43 PM
TPI K5's Avatar
Say I was to accidently solder the PROM into the memcal backwards, can I just de-solder it, flip it around and re-solder it? Or do I need to use a new PROM?
Old Aug 6, 2002 | 08:12 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Provided you didn't power it up, you can flip the chip. cheers, Bob
Old Aug 6, 2002 | 08:35 PM
TPI K5's Avatar
What if I did?
Old Aug 6, 2002 | 08:38 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Odds are if you powered up the chip backwards then its probibly been fried. Tho I have seen otherwise...give it a try, see if it will take a program. cheers, Bob
Old Aug 6, 2002 | 08:41 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Re: Re: Pocket Programer/29C256 question
Originally posted by Grumpy
Arrow I don't know.
edge C edge
Some chips will use a dot/arrow/triangle in one corner to designate pin 1 on the chip.
Old Aug 6, 2002 | 08:44 PM
TPI K5's Avatar
Luckily I ordered 2 29C256'c so I can use the other one, but do you think the ECM was hurt? If so where can I get one tomorow or thursday? When I turn the key, the fuel pump comes on, and the SES comes on but doesnt flash. Is this because I had the PROM in backwards??
Old Aug 7, 2002 | 07:36 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I've put em in backwards before in the programmer and the car, and haven't burned one up that way yet. Not to say it can't be done. Usually it's just "Why doesn't it work? Oh Crap! Whew..."
Old Aug 7, 2002 | 12:54 PM
JPrevost's Avatar
Car: 91 Red Sled
ROFLMAO....!!!!
That's how it's always going to be. My last time was when I got your 8 in1 and I installed the flash prom backwards. Car didn't start and I turned it off, put my finger on the prom....HOT. Took it out, blew on it a bunch to get it to cool down. Verifty it with PP2 and reinstall, works great.
The only prom I've destroyed was when I bent a prong and it eventually just broke off inside the 2 ceramic plates of the IC...oh well.
Scamo-2.8
May 20, 2016 07:01 PM
bryanwood74
Sep 24, 2015 09:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
