Question about VE table tuning.
Old Aug 2, 2002 | 11:29 AM
87_TA's Avatar
Believe ive asked this question before but never got a direct answer,when tuning VE tables and my scanware shows BLM value of 118 at 3200 rpm 55 kpa - since the KPA values jump by 10's do i make the move at 50 or 60 KPA? or split diff?
To date ive been changing the one that looks out of place and its been working but I hate guessing.....
Thanks for any help.
Old Aug 2, 2002 | 02:02 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Question about VE table tuning.
You try for 128s.
There is nothing wrong about 118, if the car is running right.
Old Aug 2, 2002 | 04:44 PM
kevinc's Avatar
Car: 1982 Z28
I generally look at the rest of the data and find points closer to either coordinate...like 49 or 41. Right on the median at 45 could mean either or both 40 and 50 are off to varying degrees.
Old Aug 2, 2002 | 05:02 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I would look at the scan and see if the BLMs go lower or higher on either end. So if the BLMs are closer to 128 at the 40kPa level but start to drop the closer you get to 50kPa, then I adjust the 50kPa.
Old Aug 2, 2002 | 06:20 PM
87_TA's Avatar
(you try for 128. nothing wrong with 118)
Well i would not want my wot f/a ratio to be decided off of that.
Thanks guys for (answering) my question.
Ill try to use that info.
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
