Need VATS help... already did a search!
Old Sep 10, 2002 | 03:27 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well, after trying to bypass the key and not getting anywhere we decided to disable VATS in my new chip. We checked the VATS select and VATS diagnostic, but that didn't help until I bypassed the starter enable relay. Now it starts and everything but I still get a CONSTANT security light in the dash. Is this normal? We redid the chip now and just turned the VATS select off this time. Car still starts/runs fine, but still have that VATS light in dash. Scanner says all is well, but I don't know if I need to just take the bulb out of the dash or what? Any ideas??? Thanks! BTW, through the searched on here I found alot, but not anything about the light staying on!
Old Sep 10, 2002 | 04:37 PM
Brent's Avatar
Yes. The VATS module is the heart of the system not the ECM. It controls the Sec light. The ECM and starter interlock relay are also "controlled" by the module.
Old Sep 10, 2002 | 10:37 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Unplug the vats fuse, remove the passkey module.
-- Joe
Old Sep 11, 2002 | 11:04 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks guys.I never even thought to remove the VATS fuse. THANKS AGAIN! Later
Old Sep 12, 2002 | 05:04 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Well, the fuse removal fixed that light problem. Now I just have to get it running right again. THANKS for the help!
Old Sep 21, 2002 | 10:28 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have no comp and had to bypass vats to get my starter to work, now do i still need this chip in my key to start the car or no? also where its the pass key module
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
