Runs hot
Old Sep 12, 2002 | 06:22 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Runs hot
I have noticed that my engine runs warmer than I think it should.
I have a 160* thermostat, Set the fans to both come on at around 165-170*, and still the temp climbs to around 200-210 degrees. I have the timing set to 8* intial and have not yet altered an of the fuel or timing tables. Should the car run this hot even though the fans ARE coming on? Maybe I need to upgrade my dinky stock radiator? Any thoughts?
By the way its a 92 z28 with a 383 with aluminum heads and aluminum water pump, if its of any consequence to a solution.
Old Sep 17, 2002 | 05:31 PM
leirch's Avatar
I think 200-210 is pretty good. Thats where I usually have my car run. But to answer your question. I think a bigger radiator is going to be the answer if you want it to run cooler. It sounds like your current one is maxxed out.
Brendan
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
