Knock question
Old Sep 16, 2002 | 07:22 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Knock question
Guys,
I have only been burning chips for a short while...gotta question. I am using WinBin for editing. If I turn off the Knock flag will this disable the knock sensor for hearing any knock? The reason I ask is because I have a huge power loss under moderate to heavy acceleration...it feels like the computer is pulling out alot of timing. I disabled the knock flag but the loss is still there.
I am using the ARAP bin, but I also tried a bin with way more conservative timing and it did the same thing. That led me to think that maybe the knock sensor was picking up a mechanical knock in the motor....that is why I disabled it with the flag. Currently I don't have any means for scanning while driving the car so I am just trying to narrow it down.
If my question above is true, I may just have to add a bunch of fuel to it to see if it is actually running itself WAY lean.
Thanks for any help,
James
Old Sep 16, 2002 | 07:35 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
No that flag does not disable the knock sensor, just stops the computer from checking to make sure it is working. Then you could disconnect the knock sensor I suppose.
First of all this is a very bad idea. I can’t stress this enough. To not use a knock sensor is just asking for problems. Don’t do it. Get scanning software; you can get it for free.
If your knock sensor is picking up knocks it is a sign that the timing is to high or something is wrong. Don’t try and get around it by disabling the knock sensor.
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
